TomTom Universal air vent mount convert to a dash mount?
5UUB.052.02 NEW GENUINE TomTom 5"/4.3" Car Universal Clamp Vent Mount Kit XXL XL GO ONE VIA
I purchased the above mount from Walmart and want to know if there is an adapter for the mount that will convert it into a dash mount.
Here is a link to the same one on eBay:
http://www.ebay.com/itm/NEW-GENUINE...784776?hash=item4d31c9b648:g:vcoAAOSwEeFVSit~
The back of the mount that holds the GPS unit has a "V" notch on the back. I am looking for something that the "V" notch fits into that may or may not have a suction cup and then can be mounted on the dash-
The only "dash mount" is a holder with a bean bag.
TomTom sells discs that can be glued to the dash and than the standard equipment suction mount, designed for the wind shield can be used for a dash mount.
Kiwi56
