dhn
Moderator
Any issues/problems with the installation of the 970 map should be discussed here.
@thomasjk
Did you register your 540 with an email account that you check regularly?
Anyway, these come out quarterly, but there was a delay for some models on this last 970 map. Apart from that, you can usually assume a new one about every 3 months.
Just tried yesterday because they said mid June for the delayed releases.How often had you connected with Home between May 24 and now?
