TomTom MyDrive Connect Silent Installation
<img src="/styles/default/custom/flags/es.png" alt="Spain" /> Spain
Hello guys
I need to install the application TomTom MyDrive in my company for a lot of users. To do that, i want to make a silent installation of the application. I found a switch that install the application silently ( /S ) successfully, but at the end of the installation the application start automatically and show a window to customize the language and the updates. I want also to automatize this settings to avoid any configuration and install the application completely silent.
I attach 2 pictures of the configuration window that appears.
Does anyone have any information on how to do it?
Thank you in advance for help. :)
The first time MyDriveConnect is installed on a computer, the information shown in your first screen must be completed. Further updates to MDC won't require the information. Whether this information can be done in a batch file, I don't know. Maybe support does:
España (Spain)
913496508
Lunes-Viernes: 09:00-17:30
tomtom2024
