TOMTOM HOME AND MULTIPLE GPS DEVICES.
XXL550TM, VIA 1535TM, XL340.S
Can you use TomTom Home with more than one gps device? As far as I know the application creates a single folder to store files in. Does TomTom Home create a separate subfolder for each device? I have an XL340.S that as far as I can tell was never updated and have used TomTom Home to update an XXL550TM. As I understand it you have to login using a different email addresses for each device when using TomTom Home.
Is the XL340.S eligible for free map updates? I don't really use it except for testing purposes. I'm wondering If it's even worth bothering to update.
No, you do not need to create several Tomtom accounts, just one is enough for each GPS and identified if you connect it to your Tomtom Home account.
No, the XL340. S do not have free map updates.
Since I only use the XL340.S for testing and I have other more practical options it's probably best to leave it alone and not connect it. Thx.
Lesto
