TTHome notified me that there was an update available and downloaded it, The install process started and ran for a short time when I got an error code 1260 Windows cannot open this file because it has been prevented by a software prevention policy. TTHome is on an XP machine that has had no problems updating TTHome before. The version that is on the machine that needs updating is 2.10.2.750 and the new version attempting to install is 2.10.3.900. Unfortunately this means I can not longer use TTHome because the old version will no longer run unless it gets updated.
Has anyone else run into this problem and if so, how did you fix it. i have spent 4 hours searching the net for solutions. Some registry modifications tried but no joy with any and the registry is now back to what it was originally. I also tried with no firewall and the AV program disabled and scanned for malware etc.
