EV Charging Points
Go 620
My TomTom Go Professional 620 does not show EV charging points. Any help would be very much appreciated.
Select Settings from the main menu, then select Appearance. then on Show POI lists on map
Menu / Settings / Appearance / Show POI lists on map - if "Carging Station" it shows Hide tap on that to switch to Show / tap the electric plug icon /go back to Home screen.
poi
poi
Hi, charging isn't on the list!!
From the TomTom product page
"GO Professional 520 & 620
Professional sat nav designed for large vehicles."
Could it be that because large vehicles are not generally battery powered that the designers didn't see a need for including EV charging points?
You mean you don't have this option?
ClemFandango
