At one point my download was almost complete for the new map. Then the server error came up and timed out. Same 220 error.
By the way, why is there no support listed on the website for the TomTom ONE LE?
The server is down because there is a backup in progress? Oufffbut a message might say, because the number 220, for a newbie has no meaning.
It has alot of meaning! it means this tomtom is a peice of junk.
Just curious, when you connect your TomTom to your PC, can you explore the TomTom's HD? If not, try another USB outlet.My computer usually logs in automatically when the tomtom one is connected to the computer.
My problem has been not just the error 220 but that following a login yesterday, when I opted to check out the contents of the device, I have lost from the device all the cointent that I investigated on screen. Hence no maps etc.
I have always backed up after every update, but now I cannot even reinstate from the back up; just get silly messages and the error 220
I am a computer dunderhead when it comes to this sort of thing and will be off to the shop that sold me the tomtom one later this morning.
BJ Cambridgeshire, England, UK.
Just FYI, this did not make any difference for me, I got the error even when logged in.Hey guys, I think I found the workaround with TomTom Home. It seems that if you are logged out, you will get that error. As soon as you log in, you are okay, and the update feature works.
Hope this helps.
Hi all,
I was surprised to receive my own tomtom ONE LE as a Christmas gift yesterday. The first thing I did was connect it to the internet to update, and got the 220 error (even adding tomtom to 'permit' in Symantec Firewall, and even disabling my firewall) everyone else is experiencing. At first I thought, what cheaply/poorly written software, but gave them the benefit when I saw how functionality is crammed into such a small unit. I figured it was server problems (probably has a limit it hits in a given day before cutting off everyone). The updates seemed to be working (at least at work) this morning and right now.
I have a question on the most to date USA map. When was it released? I don't want to use my 'most up to date guarentee' promo coupon if there is a new USA map coming out in the next month. Thanks!
