dhn
Moderator
For the quickfix file, try this .... on a PC
1. Use Explorer to look at the contents of your unit.
2. Find the ephem folder and delete everything in there
3. Go here on your computer:
C:\Documents and Settings\yourname\My Documents\TomTom\HOME\Downloads\complete\ephemeris\
and delete any subfolders you see there.
4. Connect to Home and you should be offered a new gpsquickfix file. Download and install it.
Before doing any of the above:
Make an Explorer, NOT Home, backup of your unit's contents. If not sure how, see here:
https://www.tomtomforums.com/genera...4-how-backup-contents-your-unit-computer.html
