Quick analysis: if I disable the Pi-hole on my VPN server, it works even if the traffic is routed from Android via the VPN server. So the problem is somewhere in the Pi-hole.
I check queries that are blocked when TomTom wants to start and compare them if I disable Pi-hole for a while.
Next URLs looks "suspicious":
- api.mixpanel.com
- remote-data.asnapieu.com
- device-api.asnapieu.com
If I allow them, TomTom starts!
Can other users with problems check if they have any apps (or VPN) that can block those URLs?
Maybe any Ad Remove software?
- api.mixpanel.com
