HELP Has anyone got a White Pearl?
Bought a white pearl for my daughter recently, and have accidentally deleted the startup image :eek:
Has anyone got a white pearl using this startup image please?
If so, could you please send me a copy of the splash.bmp file in your tomtom root folder.
I have searched Google and other forums extensively, also been told by Tomtom support that the image is not available. You are my final hope! Thanks in advance for any help.
Collin
Welcome to TTF.
Since you yourself have the image that you posted, you can do this.......
Take your posted image into a image editor program, crop the frame from the image and save the results.
Now then, upload that result to this site and create your own start-up image.
If the Pearl has a 3.5" screen, select TomTom ONE as the option. If it has a 4.3" screeen, save the image as a 720 choice.
Hi dhn,
Thanks for the reply. I may have to use that method as a last resort, but was hoping that someone may be able to post the file if they have it on their device.
Regards
Collin
