My places organisation help
Tom Tom go premium
Hi there
I have just bought a go premium and have put quite a few 50 plus addresses in my places.As I deliver stuff.
All the addresses don’t go in as I add them and are all jumbled up and I need to deliver in the order I put them in
I then have to scroll through the list to find the right address.
Is there a way to change the order of addresses as they appear in my places or any other ideas thanks in advance.
You can't retain an exact order by adding 'favorites' to MyPlaces. Sitting out there singly in the list, they come up alpha sorted, as you have no doubt discovered.
It may be easier for you to store them as a POI (*.ov2) file. When a custom POI file is displayed, the entries appear in nearest-farthest (from your current location, when viewed) order, which may be more practical for finding your next stop.
If you need help creating and sending a custom POI file to your device, let us know.
Also, if the order remains the same always, you can preface the names with
01_
02_
03_
The underscore is only to make for a visual break so the names stand out more clearly.
tomtom2024
