Droid X pairs with 730 and 720 but not 630
Easily paired my Droid X with my 730 and my 720. Address book did not download but I copied from a backup. Did not try to set up a data link.
Tried to pair my 630. It would not pair for the phone only for data (which I did not try to set up).
When I turn the Droid X bluetooth on the 720 and 730 say connected but the 630 says activated.
The phone works perfect on the 720 and 730 but does not work on the "activated" 630. Tried the 630 at least 6 times. I tried to turn off the data setting on the 630 but this did not help.
Same software on the 630 as the 730 and 720.
Any thoughts?
Thanks,
Howie
Haven't seen that before.
Try:
1) delete the droid from the 630 phone list (if present)
2) delete the 630 from all the devices on the droid
3) poweroff then remove/replace the droid battery
4) pin reset the 630 per this links
sporting41
