Startup Images for 4.3" and 5" Wide-Screen Models
Audi splash screen ....
Audi.bmp.html
Here are two that I made.
You can find the 1st one using HOME. If you do find it in home, please give it a rating.
The logo was created seperate and I used Photoshop to placed the layer over the existing picture.
Thanks!
This is the one I am playing with and what I have done so far. My bigest problem is that when I used MS paint to make it to fit my GO 920 it makes the picture stretch and a bit squatty.
If you would like to play with the world.zip and put a TT logo on it and do it in a splashW format (480x 272 px ) for the Go 720,730 920 etc. etc That would be much appreciated if not I totaly understand.
Gary
I did these in zip format as I don't know how to upload as image I just ziped & used paper clip.
View attachment world[1].zip
View attachment splashw.zip
The original image resolution was not the greatest so when I convert it to the size, it comes out like this:
I have other Earth ones if you like these.
Thanks Pedro
I had tried that first one using splash screen generator but I didn't like the way it streched out the globe.
here is the one I worked on my self and am going to use it for awhile.
I don't like the way I had to extend the armes but other than that it isn't bad.
Or this one with ALG icon:
Figured I should go ahead and toss mine into the mix. I use the computer voice "Susan", so went with a pic of supermodel Suzie Wilkes for my screen. BMP was too large to upload, so here we are as a JPG.
Oh, no! I am using Kate. Following your footsteps I would have to use Kate Moss (shudder).
I'm stealin' her! Always knew MY Suzie was a hottie!
Rep points for you!
TomTom GO 720 Startup and Shutdown
Here are Startup and Shutdown screens I made for My Elantra GT.
I just used a picture of my car....
Yeah, I had to stretch it to make it work. I plan on taking to original back into photoshop and cropping it to the right size so its not stretched but I only see it for a couple seconds a day so it doesnt bother me...
Very nice, sab. Until I totalled the Taurus I had a few months ago when an idiot ran a red light, I coulda used it! :eek:
