What is the best way to charge 903T ?
Is it in the cradle and plug into usb or via the connector to cigarette lighter of the car ?
I plugin to cradle right now and it has green light at the bottom right hand side.
So when do I know when it is fully charged ?
Will the green light go off when it is fully charged ?
And how do I check the progress of the charged ion litium battery ?
Where do I check on the 930T ?
How long is the charge assuming it is almost empty ?
Thanks.
Thanks.
