vietnamese voice for TomTom
When I go to:
Changes Preferences> Change Language
Vietnamese is not an option.
Neo
"never mind, I found it in VOICE".
Thanks for the hint.
Neo
The file whch should look something like this: dataXX.chk where XX = a 2 digit number should go in the voices folder on the unit. Use Explorer to move it there.
You may find it here:
C:\Documents and Settings\yourname\My Documents\TomTom\HOME\Downloads\complete\voices\
i downloaded the file but couldn't find in my tomtom navigation. help please. thanks
Hi Christine. I think you need wdindows RAR in order to download and unzip the file
Just google it ...download & install it in your PC .....
Now you can download RAR zipped file .....put it on your desktop and Unzip it there "By double ckick it"
You will see 3 files ....."Leave it open ....
Now plug your tt to pc ...should see device menu ...open it ...look for "VOICE" folder ...open it ....
Then Drag those three file in ...CLOSE ON FOLDERS "x OUT" ....
You'r all set to go ....just go to "Change preferences" ....."change voice" ...you should see
a "Special 12" ...click it ...
Good luck.
(BTW...Need more help ....Pm me"
Annoyed tomtom user
