My uncle, also living in the UK, has a Go 500. I bought him a year's map updates for Christmas and applied the first update the other day. In the process I had to replace the original TomTom SD card as there wasn't enough room for the map.
I managed to do this after some minor niggles. However, when the unit is switched on, all that happens is this:
1) The TomTom logo is displayed, accompanied by the drum sound.
2) The "boot-up" screen with the progress bar is displayed.
3) Another splash screen with a finger pointing at an image of a Go 500 is displayed. This image is displayed for a few seconds and then the unit powers down.
At no time does the green power light illuminate. I have tried re-fitting the original SD card but the same process happens. I have tried resetting the unit to no avail. I can access the unit via TomTom Home or Windows. I can operate the unit via TomTom Home.
Can anyone offer any help or advice on how to get the unit up and running?
TIA, David.
TIA, David.
