I have an XL 335 TM that is still under warranty. The traffic receiver (integrated with the power cable) worked fine for some months, and then never seemed to find a station (although there are 4 in this area that broadcast the traffic info). I called customer support and they sent me a new cable. It seemed to work for 2 days (I got the solid green dot, but there weren't any incidents so I couldn't tell if it found them correctly) and then also quit working, showing the moving circle (searching for a station) instead of the solid green dot.
It seems like an odd coincidence for the replacement receiver to fail, and to fail within a couple of days, unless these have a history of frequent failure. Could there be something in the GPS device itself that is making the receiver go bad? Any other ideas? I don't know if I should get customer support to send me a third receiver, or if the same thing will happen and I should try a different approach (like a whole new GPS).
Suggestions appreciated--thanks.
