TomTom xxl 530s speed alert canada
On page 2 of your menus, do you have an icon showing Enable (or) Disable Safety Alerts?
If it says 'Disable', then you DO have them enabled.
main menu > change preferences >safety preferences change warn when driving faster then allowed yesterday l will try thank you for fast ansver.
second question. can l find all poi files for canada like one file? or l have to download all them one by one?
in internet. all tomtom poi files in one rar archive. or can i convert igo poi file to tomtom? l have 40mb igo canada poi's
I suspect you want different categories, do you not? If so, you'd want to convert each category to tomtom's ov2 format.
What kind of Canadian pois are you talking about?
l am new in toronto l need all poi's
