Good to hear you got it working. I've been finding other little annoyances and bugs with the new version of the OS, so I'm hoping that another carrier releases another 4.2.1 package higher than .102 so we can get rid of some of the silly bugs
I have. Don't use manual. Just choose United States, and "Cingular Wireless (media works)". Sailed right through for me![]()
Just to repeat again... The ONLY firmware on your blackberry that will support this feature is 4.2.1.66. That's it. No other firmware version will work. You will be wasting your time if you try. APN settings don't matter if you're not running 4.2.1.66.![]()
billclark said:You may find information on how to do so here: http://www.blackberryforums.com/gene...y-release.html
r_nally, you can't be serious... did you even read through the first post in this thread?
I'm a little afraid to ask but has anyone had a BB on Verizon configured to work? I'm getting the sense that it is all about the firmware (thanks Bill) but I only see 4.1.xxx available for me on their website. Will downloading the firmware from another vendor totally screw up my BB?
Thanks,
chuck
Mr. Clark,
Won't you please enlighten us all as to where we can find the download of 4.2.1.66 along with the instructions you speak for applying it to any carrier model.
While I can't speak for Mr. Clark, I would recommend you to "Blackberryforums.com" for instructions on how to revert back to a lower level of operating system. Look in the "RIM Software Thread". The folks there are very helpful.
The last remaining "applications version" 4.2.1.66 can be found in Venezuela or on the web at: https://www.blackberry.com/Downloads/entry.do?code=D010396CA8ABF6EAD8CACC2C2F2F26C7
If this does not work for you, ask around the BB forum, maybe someone has it in some form of down loadable file. You will need to be sure that the type of carrier matches yours, CDMA, GSM, etc.
I know from experience that .66 was very buggy but apparently, from what I have read, here and there, its the only version that will allow TT tethering.
Good luck.
