- Joined
- Jan 6, 2009
- Messages
- 27
- TomTom Model(s)
- TomTom one 3rd edition
Today my USB cable arrived which I had ordered a couple of weeks ago.
First thing I done was download the TomTom home software off the Tom Tom website. Once I had downloaded the software and then started the program up automatically being prompted to an update screen. I proceeded with the update all of a sudden I got an error message NOT ENOUGH SPACE!!!!
Shortly after I clicked on fewer thing and I was still unable update as I recived a ttgo.bf error.
This was very annoying I then began to research on google reading peoples comments and came to the conclusion that in order to get rid of corrupt data I needed to reinstall the whole TOM TOM. To do this I backed up the files and formatted the TOM TOM to Fat 32 this didn't work so I used the Fat. Both ended up not working
Drive could not be formatted properly.
I now cannot access the drive whilst the Tom Tom device is plugged in nore can i use the Tom Tom software.
Can you help me?
Can you help me?
