Start 52 weak screen light
<img src="/styles/default/custom/flags/dk.png" alt="Denmark" /> Denmark
Start 52
The brightness of the screen is weak in daylight
Brightness is set to 100%
When I turn off the power (removing the ignition key), the display lights up to an appropriate brightness.
How do I get a better brightness ?
Are you plugging the device into a usb port in the car? If so, don't. Insufficient power to charge the battery AND operate the device. Use the provided car charger.
Perhaps support:
Danmark
35 25 65 14
Mandag-Fredag: 10:00 til 17:00
It turned out that I used the power supply from my old Tomtom Start 25, which was in the car. It has been replaced with the supplied power supply, and now everything works ....
So you were right about the USB port !
