canderson
Moderator
- Joined
- Dec 28, 2007
- Messages
- 13,698
- Location
- Colorado, USA
- TomTom Model(s)
Well - I do, but it won't be helpful. I'm as suspicious as anything about (yeah, old song) that bezel. Given that you're dealing with a glass substrate for the touch panel / LCD assembly, I'd sooner suspect that the plastic bezel around it was deforming with heat and placing pressure on the upper right corner.unless someone has some other info, im going to replace the screen. i found some inexpensive ones on ebay for about $30
Before you replace the screen... while your unit is behaving badly, take a thin plastic tool or butter knife or whatever and gently work it between the bezel and the case at the bottom, and from there, pry out the bottom of the bezel and remove the bezel. See if it magically starts to behave well again. If it does...
