Satellite Imagery
every time you are looking at the NAV screen you are seeing it. Nothing else to access. (just makes the images 'prettier' with the updated sat imagery)
Sorry battom, but this is not correct.
The sat images have no effect on the navigation view, ever. The only time that you see the sat imagery is in the 'browse map' view when you zoom out. Above a certain zoom level, the standard map view is replaced with the 'satellite image' with the roads overlaid.
So, to answer the OP's question;
main menu>browse map>zoom out
Kewl!! thanks!
Hey... I can't get them all right! Thanks for the correction Spook.
