Need help figuring out file/folders locations! :(
I don't have the following files in the root of my 730 that are in your 720 dhn
mctx.txt
reflush.log
ttdesk.ver
I also have these additional files in my root
modna1_512.img
modna2_512.img
modna3_512.img
modna4_512.img
modna5_512.img
modna6_512.img
Also Tim at GPSReview did start a project to document what the TomTom files are for but it died early on.
Thread is entitled What are all of those files for?
I'll be able to reply later today as I'm not at my home computer where the TT is. I wonder whether the .img files are remnants of a 3rd party program you had installed. They are graphic images. The suspendw.bmp file is a graphic file used in this situation by tomtom:
It's used when the device shuts off depending upon the setting of the checkbox for "Warn not to leave the device in the car" (Safety Preferences). I have a antitheftw.bmp because I check the warning. But, if you leave it unchecked, you get the suspendw.bmp. You can create your own .bmp's as well.
For other files..........I'll provide some info later.
It's later .... :)
Here are the contents of my mcxt.txt file:
In France using ViaMichelin
In UK using ITIS
In Finland using Destia
In Italy using Infoblu
In Germany using TMCPro
In Sydney, New South Wales, Australia using Intelematics
In Melbourne, Victoria, Australia using Intelematics
In Brisbane, Queensland, Australia using Intelematics
So, obviously info about phone networks.
Reflushlog contents:
---|INFO: preforming a cleanup...
---|INFO: Delete this file...
---|INFO: Finished.
Yeah, spelling error in the log! :D Obviously not a big deal and may have been generated when I ran Clear Flash or restore to factory defaults, dunno.
And, ttdesk.ver:
[description]
version=1.6.020
That's it!
sherra
