Help fixing a turn restriction?
mvl
Moderator
Boston, MA, USA
Tomtom GO for Android
I've been trying to put in a Mapshare edit but it isn't being accepted in my tomtom. Can anyone help me understand what is going wrong?
In Brookline MA, map 8.15, if I navigate (in route planner):
- from the small stretch of Boylston St (eastbound), between Chestnut Hill Ave and Lee Street
- to 11 Lee Street (southbound)
The route should be a simple right turn from Boylston St to Lee St. However, tomtom takes me on a huge circle, as if the right turn is not permitted. I attempted to fix the turn restriction in mapshare, but in the turn restriction screen, tomtom already permits the right turn.
What is going on? Can anyone tell me how to fix this in mapshare?
Just a super crazy guess I'm throwing out there, but it could be that another user has possibly submitted that suggestion already, has not been verified by TomTom, and perhaps your mapshare preference settings might not be set to view ALL corrections but your device already has the correction stored.
Either that, or TomTom for whatever reason thinks that making that big circle is more efficient/quicker?
Again these are just crazy guesses I'm throwing at ya.
Got it fixed. I had to block the street in mapshare. Then go in and unblock it.
