Fixed Car mount for Tomtom Go Exclusieve 7" (= Tomtom Go Navigator 7 )
To absorb the difference of 0.5 mm of the ball, I cut off the tip of the pinky finger from a latex glove and pulled it over the ball. I have taken a blue example here so that it is clearly visible in the photo, I will I use a black model. The original nut of the 7 inch nav over it...
The 7 inch nav mounted on it and it is so solid, like a rock
nicofinn04
