Will this method also work if the backed-up version is the old 7.05 mapsettings.cfg?
If not, is there anyway I can geet this one file to get my unit working again?
Mark W
Did you need the pin reset or was it good to go with just the mapsettings.cfg file from 7.221?
Does your Operate My Go still work in TTHome with firmware 7.48 and mapsettings.cfg from 7.221?
It did work in my case with 7.48 on a PC, not on a Mac
still works on PC with the 7.221 config.. mac not resolved tho..
Somebody in a different TT site said he tried the replacing of the mapsettings.cfg file and it did NOT work for him. I wonder whether it is the combination of replacing the file AND removing the support_asr.dat file that is required to get VR working again.
Wanna be another guinea pig?![]()
There you go:
Just tested twice
At my end the support.asr file has no effect,VR works with or without it
oink oink!![]()
Think he's running into issues on a Mac. You seem to say that everything appears ok on a pc, correct?
Sorry, that did not work for me.Somebody in a different TT site said he tried the replacing of the mapsettings.cfg file and it did NOT work for him. I wonder whether it is the combination of replacing the file AND removing the support_asr.dat file that is required to get VR working again.
I assume the new firmward doesn't cause TomTom to turn itself on when you connect external power still...?
