Do you think my Go Premium X is dead
I'm a bit confused as the guy at TomTom Support said if I do a factory reset it will automatically reinstall My Places/POI's as soon as I reconnect to My Drive again. I don't see how as I haven't transferred them anywhere. Is it really that easy?
Thanks,
Ron
If you have any custom POI categories on your device, you must have uploaded them via the TomTom web app. You can't direct load them to your device. If you have an account on the TomTom web app, then any favorites you create there or on your Premium X are also sync'd back and forth between them.
Thanks for the reassurance canderson, the POI's came about after I done a hard reset in the past.
Thanks,
Ron
Same for me!
My Go Premium X does not give any live services after 10 minutes into journey - it just stops and claims "no internet".
Done all the above (reset / soft reset / hard reset / factory reset... nothing works).
Never not been used - use it every week with my job... so never been drained of power. Updated every two weeks too.
Tom Tom are a joke now - no support so do not give a stuff about customer service.
Anyone prove me wrong then i'll apologise... but for the past 4+ years Tom Tom are not worth it anymore.
Same for me!
Not as unusual as you might think.
Let's start here:
Is your device linked to both your home internet (WiFi) and your phone? And if so, which method are you using for the phone connection?
1. My unit is not connected to home Wi-Fi when I am out driving (across England)!
2. It is not linked to my smartphone and never has been!
It has always worked with no issues for the past 3 years or so. So why has live services started having issues now?
I used to have another traffic unit that required an extra cable. This too had signal issues and so Tom Tom developed this type of unit for this purpose by having an internal SIM card fitted.
This is a service issue and nothing to do with tethering to Wi-Fi or Bluetooth or smartphone.
So when this unit is designed to work in a vehicle and is designed to work via its internal SIM card via gps signal then I should not have to tether it to my phone whilst using in a vehicle.
I only connect to home Wi-Fi when updating. Does not require Wi-Fi connection to work as a Sat Nav.
So yes it is unusual when they device was sold to work without tethering to Wi-Fi or smartphone as this was the design to be a standalone unit.
Understood 1 and 2.
Though it certainly could have had, depending upon your answers. You have no idea how many people with cellular capable TomTom's have driven away from home and wonder why the Live data disappears a few minutes later.
No you are wrong.
This has nothing to do with Wi-Fi and smartphone.
Like I said it has always worked with no issues until 2 months ago.
The unit should work as a standalone unit. No tethering or Wi-Fi. That is why it has its own SIM card to allow this, which it always has done for the past 3 years plus.
No you are wrong.
No, I am right. It CAN have to do with driving away from home WiFi without a good alternate connection taking place. It just doesn't happen to be so in your case, but because it can, the question must always be asked.
You are not listening!
My unit works (or rather worked) for the past 3+ years with no issues until 2 months ago.
The Wi-Fi is only for updating.
Once away from home no Wi-Fi is required as the unit has its own SIM card and works via satellite gps pick up including the traffic and services.
I have logged in to my account on the device with no Wi-Fi or smartphone tethering as it is not needed… as it works via internal SIM card gps pick up.
I had an old unit where I had an extra aerial wire to do the traffic which is why this device was designed to remove the extra aerial.
I have had Tom Tom devices for the past 18 years and so know about it.
The Premium X device is such it does not need Wi-Fi or smartphone tethering via Bluetooth to work as designed.
So there is an issue with signal or software… or my guess is Tom Tom doing clandestine things to get consumers to buy newer products.
I bloody well am listening. You're not hearing.
Even with what you say above, there was the possibility that you were driving away from a WiFi system that was providing traffic as you were departing, and that you had no alternative connection after leaving that location. If your cellular account had been allowed to 'expire' at TomTom, and had you had your device able to connect to a home WiFi system, you could have achieved exactly the symptoms that you reported. Eventually, the data goes too stale, and the device reports the lack of connection when unsuccessfully attempting to update the traffic information.
THAT is why the question had to be asked. You wouldn't have been the first to experience your symptoms with a cellular connected TomTom device due to an expired cellular account that had to be reinstated with the carrier by TomTom.
I agree, as it turns out, that this seems not to apply in your case. But suggesting that it could not shows lack of understanding that there are more use models than yours, and that some of them can create some peculiar results when things go poorly.
Sorry!
You are not listening or reading what I have said 🙃
I have a unique understanding more than you know.
But my account and services can’t be stale nor should they “expire” as I use my device weekly and have done for the past 3 years as drive all over the UK with my job. Hence I know my unit well!
And the Wi-Fi thing is again only for updating software and maps etc. Yes if one had a Wi-Fi hotspot in their car they can keep connected and gain better signal. I however do not have this and never had so do not need to rely on Wi-Fi.
But you stating I move away from home and Wi-Fi switches off is no such thing as I do not connect it to home Wi-Fi permanently but only for updating as it for maps etc.
The device is kept in my car and switched off until I switch on. So again it is not reliant on Wi-Fi!
But as you say it Tom Tom seem to retire or expire accounts then this is an issue of theirs and as such I will wait in my response from them on this to fix their issue.
This expiring of services if lifetime should not happen and is a breach of data and accounts.
But again will see what they come back with.
You still don't get it. I haven't said that this IS/WAS your problem, only that it COULD have been, so the question needed to be asked at the beginning to determine whether that belonged in our list of suspect causes to be investigated. Pretty basic troubleshooting by remote - something we do here daily.
Why is that so hard to understand?
If you're claiming to get any service over cellular at all, and you are, then your account has no issues. If your account had been allowed to expire by TomTom (it happens both after extended disuse and sometimes accidentally as well), you'd not even get that first 10 minutes of service you talk about. You'd get nothing at all.
However, because we HAD NOT YET ELIMINATED the possible WiFi issue in the beginning, this was also added to the list as part of one of the possible suspect causes.
If you're getting 10 minutes of service at the beginning of each of your trips, you've got something entirely different going on there. If you're willing to actually discuss solving this rather than just ranting at TomTom, perhaps we can get things put to rights, but we're going to have to be methodical about this. Are you willing?
You said:
“above, there was the possibility that you were driving away from a WiFi system that was providing traffic as you were departing, and that you had no alternative connection after leaving that location”
I replied “This is not the issue”
Exactly my point there is something else going on. You initially did not understand what I was telling you and you kept on reeling off the Wi-Fi scenario when I kept telling you it was no such thing!
And cellular service via the internal SIM card should not be a problem. The maps work fine. The routes work fine. It’s the live services that work for 10 minutes then go offline. So there is another issue.
But the fact all and sundry on here state “reset” or “factory reset” or “update” etc. to sort out it is not always the answer. Hence why I always try all the above but still nothing.
That said I will wait for Tom Tom to respond.
Oh and I (alongside many many others) have good reason to rant at Tom Tom. They used to be the best sat nav system out there. But now their customer support is virtually non- existent they are way down the list.
Again I’ll wait for TT to respond if they ever do.
But in future please do no ridicule people into thinking they know nothing about things. Just because you are a Moderator does not make you the top expert. Yes you troubleshoot things but after all exhausted things best to not keep stating what has already been told to you.
I told you at the start it was nothing to do with driving away from my house as not connected to Wi-Fi…
But you kept claiming it was or might be - I was clear it wasn’t.
And writing:
“You still don't get it. I haven't said that this IS/WAS your problem, only that it COULD have been, so the question needed to be asked at the beginning to determine whether that belonged in our list of suspect causes to be investigated. Pretty basic troubleshooting by remote - something we do here daily.
Why is that so hard to understand?”
This was rude after I had told you categorically that it was NOT the problem. You could not understand THAT and so continued to state it could be.
So please do not continue with ridicule as it is not polite.
Anyhow thank you for at least taking the time to respond.
I shall wait for TT to respond if they do.
Same for me!
Hi @D J Sheridan -
The built in 2G only Vodaphone SIM should keep trying to connect and load traffic/camera data only, roughly every 2 minutes. You start your journey from the same location each time? - but does this also happen at other locations? When this does occur, your Go P.X. is still on throughout the journey/route for how long? 2G is still pretty much ok for now in the U.K., but I wouldn’t be surprised if it’s slowly being reduced in some areas to free up more of the spectrum for 4/5G.
Hi
No I start journeys at differing locations across the UK. The same thing happens each time.
Scenario:
I leave home location with full live services and then roughly 10 minutes into journey the black bar appears with car symbol with line through it indicating no live services. When I check status both traffic and live services indicate no internet. This holds all through my journey up to 6 hours duration, even when I stop for break and the unit is switched off then back on again. When I create new journey like to a hotel it still does not work, although maps and journey is still fine picking up route etc. just no live services.
The next day when plotting route the live services are back again… but only for 10 minutes or so into journey again then lost again. This only resets on the following day.
I have tried everything from reset to factory reset and even logging out and back in again. Still happening.
So the sim is 2g only?
So didn’t TT consider this moving forward as being an issue if it is the issue?
Strange to sell something that is not future proof.
Is it possible to replace the Vodafone sim with a g4 or g5 one to ensure this signal?
I bet it isn’t.
It obviously picks up at start so why not continuously through the journey? Yes I understand signals can be weaker in some areas but this has never been an issue until 2 months ago.
If the Vodafone sim is 2g then shame on Tom Tom for selling a unit they know would become obsolete in time knowing the sim is only 2g.
They should send out new sims if this is the case or at best offer to replace free of charge.
And I'm perfectly fine with that. It eliminates one of the possible reasons for your symptoms, and we know we can be looking elsewhere.
I bet it isn’t.
Yes, the cellular capabiliity of all TomTom devices (except their 'Bridge' commercial units, which are 2G/3G) is 2G only.
Let's deal with this SIM issue first. It isn't "2g only". It's not anything-g. No SIM card is. There seems to be a great deal of confusion in the non-tech world about SIM cards. They have been imbued by the public with the most amazing and magical capabilities.
SIM cards pretty simple storage devices. They store an IMSI ID to identify themselves to networks, address book info, etc. They are NOT radio frequency devices. They do not determine what frequency bands or protocols the phone is capable of using to communicate with cell towers. They do not receive. They do not transmit. They do not, therefore, decide whether the phone is capable of communication on 2G, 3G, 4G or 5G, or whether GSM or CDMA is used. Those features are the function of the 'radio' (modem/transceiver) hardware in the phone.
Sending out new SIM cards cannot solve the problem. Instead, you'd have to replace some serious internal hardware to do that.
So you're correct with your "I bet it isn't" assessment. Swapping SIM cards can't turn a 2G device into a 3G, 4G or 5G GSM device. That said, "Strange to sell something that is not future proof" isn't fair, as it applies to the manufacturers of every single device built in the 2G era, and there are many out there other than cell phones - think GPRS. An entire industry was rocked by the shutting down of 2G as has already happened in other parts of the world. You're lucky you've still got 2G in the UK and most of Europe.
The ongoing shift in cell industry standards is probably why TomTom gave up chasing them and left the user to make the connection, assuming they would be au courant with regard to whatever the cell companies were doing with the user's cell phones.
Finding an inexpensive cell solution that was still capable of worldwide use back in the day was tough, but 2G fit, and wouldn't cost TomTom a fortune in data usage. Remember, you bought the device, but they paid the monthly bill. The 6200 was released back in 2017. They've already paid over 84 months of cell data bills for the early owners of the 5200 and 6200 owners, and as many as 132 months for 5000 and 6000 (released in 2013) owners. And I would point out that these devices allowed for roaming as well. Done on your own, even a 2G cell bill would have been substantially MORE than what you paid for the device.
Now that we've got the SIM fact/fiction sorted, let's get to work on your specific problem.
Again, if you're getting data over the cellular network at ANY time, we're not looking at a lapsed or cancelled cellular subscription problem. Once that would happen, you'd get nothing at all until the account was reinstated.
Here's something that has worked in the past:
To access the SIM card, gently peel back the left label at the bottom of the device. There you'll find the slot with the SIM card in it. If you push the SIM card a bit, it will pop out of the device. Gently buff the contacts with some soft cloth. Reinstall the SIM card. Make sure you insert it back in the with the correct orientation. See if that changes the behavior at all.
If not ...
Hi
Scenario:
If the SIM card buffing was of no help, let's use a bit of divide-and-conquer here. The next time you are home with your device for a couple of days, hook it up to mains power in your house. Don't instead power it with any computer that's ever had MyDrive Connect installed on it. We don't want to accidentally get traffic data via the computer. Best to just use an USB charing adapter and cord on a mains connection.
Make SURE you have NO connection to any WiFi data source by using Settings / WiFi / select any prior connections that show 'Connected' / Modify / Forget. Unpair Bluetooth connections as well if you've ever connected with that. We don't want to be fooled into thinking the cellular is working when it's actually getting data from some other source.
Now, plan a route to any arbitrary destination. Make sure that traffic data appears on the device. Wait a few hours (essentially, much longer than the usual 10 minutes of service you seem to obtain) and look again. Operating in a stationary location for an extended period, does your device lose or retain its ability to see traffic data? Perform this on a couple of different days and see if anything changes.
I'm trying to remove all of the location, vehicle environmental, temperature change and vibration issues entirely with this approach.
Well I will try the sim thing.
To note like I said the device is not connected to Wi-Fi or computer. Only Wi-Fi when updating etc.
And I have no Bluetooth connections as do not link anything to the device.
So not sure on the journey tests etc. but I see your point on that.
Also to point out I only ever power the device at home with outlet usb socket and not a pc.
To note whilst testing the unit last night a message came up to state it had detected I had not moved location for some time so was going to shut down in 5 minutes.
Not seen that ever before.
Thing I did note was the traffic services remained on for at least 30 minutes. So a positive there. I was 5 miles away from home at this point and was not connected to my smartphone as never have had it connected.
Best chance of test is on Friday as travelling 52 miles away. So will see if things are better or not.
But I’ll give it some time.
That said Tom Tom have responded claiming they have a high volume of customer inquiries (go figure. Create mayhem and chaos then do not be surprised this bites you back ten-fold).
Hopefully they will respond back soon to check on things.
Will keep you posted.
kickstandsup
