Best Mounts available
Look at www.proclipusa.com for excellent mounts for TomTom, cell and other devices.
Be creative and integrate the factory mount; I did; into the dash bezel of my Durango. I blocked the vent to keep out heat/cold. 20 minutes of time to embed it into the dash, quick removal and I can watch Family Guy on the way to work (In traffic).
I just wish the auto on worked. Being in New England the temp changes would caused the suction mount to fall off. and it was a pain to reach over the steering wheel while driving and TomTom was sliding around....
Thanks for the responses for my question regarding raising my unit up and inch or so to accommodate the cables/connectors (deleted soon after I submitted it because I just bought a third-party mount).
I ended up getting a dash mount on eBay which will offer my unit the height I needed...
It'll bring the unit a little closer to me so I won't have to lean into it (Honda Element).
Unfortunately, having it above where you have it, jinferrera, which puts video content in a distracting position- and I'm easily distracted. LA rush-hour traffic kind of levels the playing field though when you're sitting on the 405 parking lot.
It was $11.95 (Buy It Now) + $6.95 (shipping) = $18.90. There were some others that either offered a longer arm (bringing the unit closer in which would be better if you have to mount further back on your dashboard closer to the windshield) among others.
Looks like there's a pretty good selection out there. I was originally looking for something really simple, but another mounting kit all together will make it easier to shuttle the GPS back and forth between my car and my wife's, so it's all good.
Great idea! I'm trying to do something similar w/ my Taurus, just haven't had time yet. I'll try to post some pics after I am successful. How well does the included little plastic disc work for "non windshield" attachment?
Very happy with my Tomtom ONE XL, but the mount is another story. Any alternative mounts (dash, cup holder, vent or windshield) out there ?![]()
How/what is that mounted to?
