720 with VR and 8+ software possible?
I tried an I got the csspeech files but the new 710 map won't let you add to the .cab file
You DON'T add the cab file to the 7.10 map folder. You EXTRACT the files from the map folder in the .cab file (which is a compressed file) and then copy the extracted csspeech files to the specific map folder on your unit.
Right click on the .cab file and you should see a menu option to extract files. Go from there.
Tuinboon
