I have the file (older version 7.14) and I would be happy to share it with someone who needs it.
I would like to have a copy as well for future reference...incase my xls starts doing weird things mentioned here. Thanks
So, I am not the only one with this issue!I finally.. after 1.5 hours with TomTom tech support got the problem solved. I have the file (older version 7.14) and I would be happy to share it with someone who needs it. It was a very frustrating day. Also, I am on a Mac, which made things even more complicated, but with reverting to the older version firmware and re-downloading Susan it fixed the problem.
I also asked why this firmware is still available if it is making all the xl's loose their sound. The response I got was.. " They are working on it!" I don't understand why they don't at least remove the update.
Anways...I am happy to share the download, to save anyone the pain that I had with tech support today.
similar problem here. Had backed up, but only after installing 7.161!Just bought a TomTom ONE XL-S. After a day of use, I was a happy camper. Then I upgraded (from 7.14) to 7.161 via TomTom HOME. Lost all sound, except initial "drumbeat" on startup.
Phone support tech led me through various steps, including a downgrade to 6.5xx, but nothing helped.
The last step that I had discussed with the support tech was restoring to the original software. (I had (thank goodness) done a backup via TomTom HOME prior to upgrading to 7.161). Initially, the tech said that would not solve the problem. By the end of the call, after other steps has failed to restore the sound, she agreed it was worth a try. I thought the restore would take as much time as the original backup , about 45 min, so I ended the call. Then I deleted the TomTom application from the TomTom, and did a restore back to version 7.14, which completed in only a few seconds (It looks like a TT HOME restore will not overwrite existing software--you have to first delete from the TomTom those parts you want restored).
My sound returned.
I am not going to try to upgrade to version 7.161 again, though I might try again with the next update after 7.161.
Hi Barryg41,I also updated my TomTom One XLS. The only thing that went haywire was not having the ability to turn it on unless it has some kind of power supply plugged in (i.e. USB, in the car). Everything else is good including TTS. I do have a 7.14 backup but this is not a problem for me right now.
I also have the UK maps on a SD card. Its works normal when the SD is being used. Go figure!
I consider my self lucky! I can live with the way it is working right now.
Thanks so much for the file ebuyer.I finally.. after 1.5 hours with TomTom tech support got the problem solved. I have the file (older version 7.14) and I would be happy to share it with someone who needs it. It was a very frustrating day. Also, I am on a Mac, which made things even more complicated, but with reverting to the older version firmware and re-downloading Susan it fixed the problem.
Hi Everyone,
I can't attach it in this forum, because the limit of file attachment size is 8.5MB, so feel free to PM me. I have sent it to a few people already.
Hi Barryg41,
I had the same problem after updating and tech support did solve that issue for me. They told me to turn the unit on, connected to a power scource then disconnect it from the power and let it reboot itself. Then, once it had done an automatic reboot and was running, use a paperclip or similar to push in the reset button (on the bottom under the sticker that says no SD card necessary) until the unit shut itself off. Since doing that I have been able to turn it on and off normally.
Can you load a back up copy of XLS in an XL and play computer voice??/
