XL unit having problems
england
xl
When i turned on my xl the screen is showing 2 rows of technical jargon, can't turn it off. Have tried to reset but same info comes up, also not showing as connected when connected to computer. Have only used it twice and not had a problem before. Any ideas?:confused:
Welcome to TTF. I changed the title of your thread to something more meaningful.
These two rows you are referring to, are they on a black screen with white writing and, if so, are there just two rows of info on that screen?
Is it possible your power button is stuck?
Yes thats spot on.
Have tried that and seems to be working o.k.
johnnytis
