Where are the Las Vegas Casinos
It's great having a POI for casinos but in maps v650.1109 and v665.1293 the casinos/hotels on the strip are not there. Or should I say - I can't find them.
All of the major casinos are in the Reno and Atlantic City POIs.
Any help?
On map v6.75, there are casinos. It was necessary to display 'hotels' too, as some of them are both hotels and casinos.
Thanks jimbo for looking. My versions show the little casinos and the downtown ones but not luxor, mgm, etc that are on the strip. Does 765 have all of them? I hate to think that both of mine were bought within the last 6 months need an expensive upgrade.
I wouldn't call it a very complete list. You might have more luck using the street addresses. For example, I couldn't find the Bellagio listed as POI.
New update
I went to tomtom.home and downloaded the home v2 and updated my one.
And now I have all the casinos. They are not in the drop down menu for Las Vegas because they are too far from town. But if you do the find under casinos they come up. This did not work that way yesterday so I am assuming it is in home v2.
tony1260
