Way points Vs Stops
Rider 550
Hi
How do I get my rider 550 to differentiate between a waypoint, the white dot (done to manipulate the route) and a stop (a place I want to visit). If I sync as a track, then all the stops disappear but if I send stops to device then everything is treated as a stop.
Sorry if this has been covered before and thank you
Tomtom does not recognise the difference, waypoints are just waypoints there are no stops.
germangholami
