Use car radio to change volume in 930
Canada
930T
How come after I updated the North Amnerican and Europe maps to 8.351 in TomTom 930.
When I play TomTom Jukebox.-
It says "Use car radio to change volume" ? I have to go to fm transmitter section on gps to disable it.
The TomTom Jukebox will start playing sound from mp3 file.
After I turn off gps and turn on gps again same thing happen again. I have to disable again from fm tranmitter.
Is this a bug? What can I do to correct this?
Zhong
Do you want it to play on the internal speaker all the time?
If so, change speaker preferences and set music to internal speaker.
MGPrewett
