TomTom pro 520 voice
<img src="/styles/default/custom/flags/pt.png" alt="Portugal" /> Portugal
Pro 520
Hi buy a used TomTom pro 520
But they have only french voice I want install other voice but I don't see how do that , I make recovery and nothing, is updating everything map 1105, traffic ok, but I can't add other voice, I hope someone can help me
If no voice on your GPS Install Mydrive Connect on your computer then look if the voice is available.
Even the 'WiFi' models allow you to use MyDrive Connect for voices.
With your device connected, click on the "MY CONTENT" tab at the top of the screen.
Scroll down and you should see sections for "MY MAPS", "MY SAFETY CAMERAS" and at the very bottom, "MY VOICES".
Click on "Add voices to your device"
If you want a voice on Portuguese, you should be able to install computer voices Joana.
Here is the MyDrive Connect screen with my GO 620 (the 6" version of the model you have) that shows the voice you will want to add:
Hi
Thanks but with my 520 nothing I will tomorrow morning
Hello is ok now, I make a hard reset and connect another time to mydrive connect, and bingo I have all the voice thanks everybody
tomtom2024
