TomTom One 140S, no battery power indicator on status bar......
Hey everyone,
I noticed that on the status bar (on the bottom right hand corner where the time, mph, and satellite signal strength are displayed) the battery power indicator isn't automatically displayed. Now I DO know that if you TAP the status bar, then another screen comes up that shows you the "status summary", which gives you a view of a few things, including the battery power icon, but I was wondering if there was a way for it to be displayed on the 1st view of the status bar, without having to tap it to get the battery power information. Any help would be greatly appreciated!
When your battery gets really low, you will start seeing a blinking red battery symbol just above the status bar, so you'll at least get some warning before it shuts down.
TomTom units are meant to be used with car chargers; that's why they are provided.
