I have a Start 60 with lifetime map upgrades, which I have not updated for several years. I loaded My Drive Connect onto my current Windows 10 laptop. When I logged in it showed the Start 60 under My Devices but the option to upgrade to the latest European map didn't appear. I connected a second Start 60, which was identified and I added to My Devices. It was only then that I noticed that the second unit was showing as 'Connected', when I plugged in the USB cable, whereas the first unit showed as 'Not Connected' when I plugged it in. I don't know whether it was showing as connected initially.
I have subsequently tried changing USB ports; using another TomTom USB cable and re-installing MyDrive Connect to no avail. I looked to delete the TomTom drivers under Network Adaptors, as recommended in the TomTom 'Navigation Device Not Connecting to Computer' guidance, but no Tom Tom drivers appeared in this location. However, as the second unit connects I presume that the drivers are ok.
I then tried deleting the original device from my account to see if it would show up when I reconnected the unit but it made no difference.
I am now wondering whether by having a second Start 60 linked to my account whether it prevents My Drive Connect from seeing the first? Also, whether having deleted a device whether I should be able to re-add it to my account?
I should mention that I recently changed the battery in my first unit but can't see why this should have had any effect.
I should be most grateful for any comments or suggestions as to what I could try next.
