Screen problems
Tom Tom one xl 4et03
image.jpg I just do know what’s going on.
That model has been decreed as End of Life by Tomtom. See here for versions starting with serial numbers shown:
"L1">ONE XL, 1GB + SD 2GB, TomTom HOME NAV2 EoL
"L2">ONE XL, 512MB + SD 2GB, TomTom HOME NAV2 EoL
"L3">ONE XL + SD 2GB, TomTom HOME NAV2 EoL
"L4">ONE XL, 1GB + SD 2GB, TomTom HOME NAV2 EoL
"L7">ONE XL, 1GB + SD 2GB, TomTom HOME NAV2 EoL
"L8">ONE XL, 512MB + SD 2GB, TomTom HOME NAV2 EoL
"L9">ONE XL, 1GB + SD 2GB, TomTom HOME NAV2 EoL
meaning no more map updates.
Also, see here:
https://us.support.tomtom.com/app/answers/detail/a_id/23935/locale/en_US
So what shall I do now? New one?
If you do consider a new one, call Support, tell them your current device is in the End-of-Life list and ask themwhat discount might be offered if you were to buy a new device.
abowen
