Request: Bundle of all SPEED Traps and Red light cameras for USA (mainly just SC)
Charleston, SC
GO 910
Or, is there an easy way to add speed traps, like if I went to speedtrap.net or where ever, is there an easy way to add the pois?
Josh
If someone has one created for all known speedtraps in SC, it would be appreciated.
I currently run a Beltronics RX65 RD, but, adding this would help even more.
Josh
Josh
You have a radar, no need for speed traps...hehehe
I'm going to move this thread to the request forum so perhaps someone can help you out in your area.
Possibly that, aswell :)
You can combine multiple POI files (.ov2 extension) and appened them using POIEdit2007 or POIEditor.
a radar would be the best option. the speed trap information I've come across on the net isn't always helpful. Unless you want your unit to alert you on a speedtrap that only occurs for 2 hours during the day.
ZorroNY
