Replacement Power Supply
TomTom Go 520 Wifi
Hi,
I need to replace my old power supply for my Go 520 Wifi. It is marked with 4UUC6B but the only one I can seem to find as a replacement is a 9UUC.001.00
What is the difference between the two?
Ah, that's interesting...
The site I saw the 9UUC.001.00 on listed it as one of these not the car charger you all mentioned.
It is one of these mains charges I actually need not a car charger - basically the store I found this on has confused the issue no end.
Does anyone know the correct part number for the mains charger. My original one was marked 4UUC6B and it doesn't turn up many links in a search so was wondering whether this was still a current product or whether it has been superseded?
If possible I'd like a variant with the multi plugs for the different countries - not sure whether they all come with those or whether it is a specific part number.
If you are looking for a mains charger, a smartphone charger is suitable for charging your GPS.
31Den
