Questions on GO Basic 6"
VIA
Hi,
My 10 year old VIA is no longer supported, so I'm looking at a GO Basic 6".
I've added my own POI's with BMP icons and OGG voice files to my VIA, can icon and voice files be included on the GO Basic POI's?
I have also added my own opening screen pic with my phone number for if its lost, can you do this on the GO?
Can you set the distance that POI's are notified by voice, assuming it has voice notification?
The manual dosn't seem to cover much technical stuff..
Thanks,
Mick
Afraid none of the newer models have features the older ones had (like custom opening screens, etc.)
Lesto
