Problem linking Google map to TomTom 930
I used Google Maps to locate an address that I wanted to drive to. I tried to Send to GPS. However, when I selected Link, I was only allowed me to link via e-mail. I did not get a choice as to where I wanted the "send" to go. I assume I am doing something wrong. can anyone help me?
Tom Casselman
I think this will only work with business addresses. Here's a link that should help:
Can I use Google Maps on my TomTom?
http://maps.google.com/support/bin/answer.py?hl=en&answer=85887
To the right of 'Search Maps' click on 'Show Search Options'.
Then use the pull down box showing 'all results' until you see 'Businesses'. Then enter the business name. When Google map finds the right address, click 'send'. You'll see the choice to send to GPS. Select TomTom and follow the prompts. You must have TomTom on and connected to your computer with HOME running.
Hope this helps.
Note that the "Send to" from Google only works for business addresses and not residential from what I understand.
abowen
