Pre-installed voices not pre-installed?
Europe
VIA Live
When I set the language to Indonesian, I was referred to the screen where you can select voices. There I can find two Indonesian voices, Budi and Irene, but they are both greyed out, unlike the others...
How can I enable the Indonesian "pre-installed" voices? I already tried googling to download the .vif and .chk files, but I didn't find any :(
tia for your replies!
Do you have the Indonesian map selected? (Is there one to select)?
Did you try a drum reset by holding the power button about 20 seconds till you hear the drum sounds?
Here's a link to contact CS:
http://discussions.tomtom.com/t5/GO...mbers-to-contact-Customer-support/td-p/373116
Oh do the voices come with the maps? I only have the European maps installed, not the Indonesian ones. Is there any way I could enable Indonesian voices anyway?
I didn't try the drum reset yet.
No, the voices aren't associated with the maps. I was just curious. Did you make the call?
BigginsBagginsBoggins
