Not able to change sound for poi
UK
TomTom One v1
Have a TT One 3rd Edition....... Brought it back from the dead but when I try to change sound of poi warning throws up a screen saying no photos found....I presume some file or other has gone missing?
Any help appreciated....
Do you have a backup of the device's contents?
Are you looking in the 'sounds' folder on the device?
You are aware of the fact that model has been decreed End of Life by Tomtom, meaning no further map updates?
Sorted now....TT has pocketgps camera warnings (on when I got it} and the sound files were not in the sounds folder, so I d/l 'd them from their website...everything fine now...but it was your mentioning sounds folder that led to the fix so take a big bow
ZorroNY
