Next maneuver not displaying
Tomtom go app
Hi I am using TomTom go app on an android phone, when I set a destination after starting the app the first destination will show the little blue box in the left hand corner of the screen showing next action IE
left turn/right turn/roundabout.
But when I set another destination it won't show again for all the rest of the stops. Also it occasionally zooms all the way out so it's just displaying an image of the globe, I've cleared the cache also reinstalled the app but no difference, anybody had this and if so did you resolve it
Thanks for any advise
Vanishing direction field is currently known bug (it was mentioned on forum somewhere) - you need to cancel the route and start it once more as a workaround. We all are waiting for fix
Cheers mkz, I did try searching but wasn't sure what to search for. I hope they find a fix soon as I use it for my deliveries. I plan a route doing a few drops at a time. But it's OK for my first drop then it loses the directions. And restarting everytime doesn't really work that well.
germangholami
