Need 340s help!!!!!
I recently purchased the 340S, which is supposed to say street names out loud. I have Susan (the computer voice) selected, and checked that I wanted street names read aloud, but it has not read any (or even attempted to read any). What am I doing wrong????
Pleas help!!!
When you selecter Susan, did you click 'test' and, if so, did you hear anything?
If so, try to reset the unit. I think your model does not have a reset hole. If that is the case (no hole), hold the power button for 20 seconds.
does that help?
johnnytis
