My Drive saving planned routes as a Track on G06000?
G0 6000
I plan and save a route with multiple stopping points on MyDrive thinking it's much easier than doing it on my device
But when it syncs to my device it is a "track".
And "tracks" do not include stopping points.
Am I doing something wrong?
Because if this is what it actually does I can see no point in planning a route with stopping points on MyDrive.
Anyone help?
When you add a stopping point to your route, it is because you want to go through this point, it is up to you to stop at this stopping point.
Go 6000 shows the distance to stopping points on a route when travelling, tracks don't show this since they don't have stopping points.
Also a route can be modified on the device (add / delete stops), tracks can't.
On a saved route you cannot delete a stop, but if you have installed the Mydrive app on a phone you can delete the stop.
On GO 6000 if a route is created on it a stop CAN be both deleted or added
A Track cannot be similarly modified
I don't have MyDrive on a phone, irrelevant to my question
I asked if a route can be saved from web Mydrive to my GO 6000 as a Route and not as a Track
You haven't answered that question but It appears from what I'm seeing, it can't which, for me, makes the creation of a Route on the web Mydrive redundant
Lesto
