:wave::wave::wave:
So my dad is about 52 and needed help with his tomtom. I'm a bit more technical than him so offered to update his maps after having the same map for the past couple of years now.
So I went on to the site as usual, downloaded the maps, downloaded some voices etc and after following all the instructions the 'Maps not found' screen appeared.
So my first attempt of fixing this was to rename the downloads folders and reinstall the back up of the old map. Didn't work.
I got a paperclip and held the 'reset' button down. Didn't work.
Emailed TomTom support a few days a go. Didn't work (heard nothing back)
Is there anything else I can try? And is there anyway I can get the new map to work? My dad is also impatient and starting to put pressure on me to get the stupid thing fixed.
It's the TomTom One 3rd Edition
Thanks in advance
Thanks in advance
