Load GPX File to Camper Max
Camper max
Hi All, I've been trying to load a GPX file that I have downloaded. If I go into my routes I can't see any files or places where they might be stored? I get from my routes>add route>search addresses & POIs?
Cheers
Paul
How are you attempting to "load a GPX file"? It needs to be the right kind of *.gpx file (there are 'flavors') and it must be added at the TomTom MyDrive web planning site ( https://mydrive.tomtom.com/en_gb/ ) and if successful, will be sent from that website to your device, which must be logged into the TomTom 'cloud' using the same email/password you are using for the web site.
31Den
